jagdriver727
Site Donor 2021
Someone recently gave me a one-owner 2002 Honda CR-V with 160k on the clock, it has the 2.4 i-VTEC and a 5-speed manual, is AWD. Neat little car.
The PO had been bringing it to my shop for maintenance since it had about 50k on it. We try to be fairly by-the-book as far as fluids used and at what intervals, but...
I popped the cap off the coolant overflow tank, to see a green-ish antifreeze inside. It calls for Honda Blue.
I checked with the guys around the shop, and nobody will admit to ever having changed the coolant. I did not personally do most of the work on the car, maybe an oil change here or there, I have never touched the cooling system.
It may have been changed or flushed at some point before I ever saw the car. 50k seems a short change for factory coolant, but it is possible.
So what would the BITOG community do? I was thinking a couple drain/fills with Zerex Asian Blue or something similar.
