Code:
ATF used AMSOIL ATF AMSOIL ATF AMSOIL ATF Honda ATF Z1 Honda ATF Z1 Factory fill
Sample Date 29-Nov-2007 Sep-11-2007 Jan-19-2007 Jan-28-2006 Jan-29-2005 Mar-13-2004
Miles on oil 2,974 15,018 15,003 12,836 10,224 21,948
Miles on car 78,003 75,011 60,011 45,008 32,172 21,948
Make-up oil None None None None None None
Aluminum: 82 118 74 36 27 26
Chromium: 1 1 1 1 1 1
Iron: 54 104 70 60 53 59
Copper: 8 18 8 7 7 9
Lead: 2 2 3 2 1 1
Tin: 0 0 0 1 1 1
Molybdenum: 0 0 1 1 1 0
Nickel: 0 0 0 0 0 0
Manganese: 0 N/A 1 1 0 0
Silver: 0 0 0 0 0 0
Titanium: 0 0 0 0 0 0
Potassium: 0 0 0 0 0 0
Boron: 140 138 209 243 228 222
Silicon: 15 24 14 10 10 11
Sodium: 11 8 7 4 6 9
Calcium: 205 389 323 388 351 334
Magnesium: 44 123 136 258 221 208
Phosphorus: 374 239 176 2 8 3
Zinc: 82 159 206 356 320 242
Antimony: NA 1 N/A N/A N/A N/A
Barium: 1 0 1 2 3 4
Viscosity 100C: 6.13 5.9 45.8 44.3 45.4 45.0
Viscosity 40C: NA 27.3 N/A N/A N/A N/A
Flashpoint: 410 355 365 340 350 355
Water: 0.0 306 (KF) 0.0 0.0 0.0 0.0
Insolubles: 0.1 0 (soot) Trace 0 0 0
Glycol: NA 2.77 N/A N/A N/A N/A
VI: NA 174 N/A N/A N/A N/A
TAN: 1.7 1.13 0.9 0.5 0.4 0.4
TBN: NA 0.6 N/A N/A N/A N/A
Fuel: NA 0.953 N/A N/A N/A N/A
Oxidation: NA 58 N/A N/A N/A N/A
Nitration: NA 6 N/A N/A N/A N/A
Sulfate: NA 59 N/A N/A N/A N/A
A drain & refill of 3 quarts has been performed at every sample interval. The magnet is always cleaned. AMSOIL ATF was used at the latest D&R. I plan on doing a D&R every 3k miles for the next few intervals. ~ 95% of original factory fill is gone.
No shifting problems. Fluid level is good.
The radiator pressure tested fine. The coolant level has not dropped since the last change. This is checked after being stone cold in my garage in the same spot at pretty much the same temperature.
Lead: 2 2 3 2 1 1
Tin: 0 0 0 1 1 1
Nickel: 0 0 0 0 0 0
Silver: 0 0 0 0 0 0
Barium: 1 0 1 2 3 4
