.010"-.011" backlash DANA 60 ok?
MO USA
I just drained the fluid on my E350s DANA 3.55 differential. I decided to check the backlash and it looks like there's about .010-.011" depending how hard I push and pull on the ring gear. I checked it in vehicle with the spindles pulled out, drive shaft still connected. Am I likely to hurt anything leaving it as is?
Lakeside CA and Lake Havasu City AZ
That seems about right. The spec. I found for a Dana 60 thru 70 is .006 to .010, so you're right there. Leave it alone unless there are other problems. Once it breaks in and takes a set, you don't want to change it, as that moves the contact area slightly.
777funk
MO USA
Thanks, I'll probably put the heavier weight 80 140 in there and call it good then.
