01 Sentra SE Auto Tranny
Al
Elizabethtown, Pa
I have fill and drained maybe 8 times in the last 5 years. This auto tranny is very hard on oil. Vehicle has 70K miles and I use various brands of Dextron III. I put in some Mercon V this time.
Analysis by Butler.
CU...17
Fe....8
Cr....0
Ni....0
Pb....2
Sn....2
Al....3
Si....3
Na....3
Mo....3
B.....91
Ca....181
Mg....1
P.....280
Zn....21
Vis 6.0
I think the results are good. But bear in mind I do a drain every 8 to 10K.
This has got to be the cleanest transmission on the road today! It will be interesting to see how long this one last for you. I think you could double your change interval and still last forever.
These trannies are not known for durability. The first one went out at 300 miles. I probably can't do enough to keep it going for the duration. At less than 20 bucks per year its good insurance.
Is there any issue switching between a Dexron III and a Mercon V ATF?
Does your transmission accept both specs?
My stepmom has a 00 Sentra which I drained some fluid out twice. I only did it cause it looked a little dirty and it shifts perfect. I don't intend to change my fluid again on my SER. I didn't know the Sentra had issues with their trannys Al. I will watch the fluid more closely Thanks.
