01 Jeep GC new injectors=significant MPG increase
Near the beach in Delaware
I had new injectors put in my Jeep and went from 19 to 26 MPG. I believe the injectors were original and had 155K miles. The engine is a reman and has much less but they would have used the old manifolds, etc. The new injectors are 4 port injectors that are a direct fit for the OEM single port ones (new ones supplied by Trav (Paul)). I was expecting 10 - 15 % improvement but this is about 25%. But as they say YMMV.
Whoa, that sounds almost impossible. What brand/ model are they? My grandpa and brother have Cherokees with the 4.0L
Contact Trav.
Originally Posted By: 3800Series
Any lose of power/ acceleration?
Runs slightly smoother, everything else the same. The Jeep 4.0 was never a "race you off the line" kind of vehicle.
That's a very common outcome with the injector upgrade. Did you use "neon" injectors ? I have alway had noticeably smoother idle aswell.
I didn't think anyone ever got 26 MPG from a 4.0, especially a GC. My mother had a 2000 and I don't think it ever broke 20. Great vehicle otherwise.
Trav hooked me up as well and the increase in mpg in my van was a tremendous improvement. The 27 year old injectors were tired.
I can buy this. If you had some really gummed up and blocked injectors, your vehicle is now operating at optimal efficiency and you are finally getting a good fuel/air ratio. Now stop using cheap gas and start using MMO in the tank to keep those injectors from getting blocked in the first place! cool
I have been wanting to do this to mine for a while now!
The spray pattern on the stock injectors are horrible.
How are you calculating MPG's. The old fashioned way or electronically?
Originally Posted By: xxch4osxx
I wonder if new injectors would make a difference in my Silverado.
These GM use a decent Bosch injector with a spray good pattern. Cleaning these can bring them back to 100% no need to replace (unless one is defective) or upgrade.
The vehicle has an overhead trip computer that gives avg MPG and a few other items.
I will stick with the 26 MPG and leave the MMO on the Walmart shelf for others to purchase.
Trav, how about a 2007 Chev Uplander 3.9?
