0* cst for various oils
JT1
Michigan
Hi, here are some 0c(32f) cst for various oils. I found these using a visc. calculator that uses the 40c and 100c cst ratings and then calculates your target temp.
Rotella T Synthetic 5w40-457cst
Valv. Conv
5w30-314
10w30-382
10w40-543
SAE30-559
SAE20w-265
Valv. Synpower
5w30-284
10w30-332
0w20-216
Mobil 1
5w20-230
Mobil Clean 5000
5w30-311
10w30-383
A viscosity calculator that uses viscosities at 40º C and 100º C won't be very accurate at 0º C.
I was thinking the same thing. These calculators have their limitations, but I guess it's a start.
That correlates pretty well to my valvoline bottle shaking experiment this year.
At above 0, I couldn't tell which was which, Valvoline conventional or Synpower 5-30. But the 10-40 was obvious.
At ten below, you could tell all three apart but the difference between the 30's was negligible.
Unfortunately, I didn't have a valvoline 20 weight available for shaking.
Well then what temperature will it be accurate to, and what are you basing this claim off of?
Visco calculators are generally accurate to freezing (they calculate VI from the 40C and 100C viscos), but not below freezing.
Originally Posted By: JT1
Well 0c isn't below freezing is it.
Relax, JT ..I would assume that there's some inaccuracy that grows the further out you go, but I also imagine that the results will be close enough for comparative view.
+1
My understanding is that the Widman Calculator is accurate down to 0C and pretty good down to -10C. If you are comparing oils of similar base oil composition you can go lower than that if you're simply want to know relative comparisons.
