Originally Posted By: Pablo
That just looks nasty. What kind of heat does this thing see? It's only 90K and it's coked and gritty? Some type of I base oil?
Is this the Haldex TC with the Volvo fluid recommendation?
Yep, this is the viscous coupler. Basically, it's a computer-activated wet clutch which sits in front of a rear differential. The rear differential has its own fluid (which also looked really bad, but no chunks).
Here's a picture of the unit for those interested:
http://i93.photobucket.com/albums/l64/JAGMAN06/Haldex_awd_generation_3-01.jpg
There's no alternative for the fluid, Volvo AOC fluid is the only option. At
$28.00 for 300ML I'd think it's not a type 1 base oil, but who knows?? I don't know what sorta heat it sees, but it obviously seems like too much for this fluid for this length of time.
It was working fine, BTW. So, it probably would have went humming along, until it didn't...
Here's a picture of the media opened up. Again, it's even worse than the picture. At least this little guy seems well-built. Steel mesh and a synthetic-appearing media:
