I have one car (CRV) that anytime you don't drive it for awhile and it sits outside for like two weeks the brakes always stick to the rotors as to where you put it in drive you hear them pop free and then the rust sounding spot of the rotor as you go down the road until it wears off.
The specs on the honda list the brakes as Ventilated Front Disc/Solid Rear Disc Brakes (in, front/rear)
It is always the rear that sticks. My other car gets this to but not to the point that it sounds like the brake pads are rusted to the rotor which where just changed less than a year ago.
Is this normal?
last year this happened after the CRV sit for 10 days and after that one of the rotors needed to be replaced so we replaced two on the back as it seemed to warped from sitting in the parking lot to the point using the brakes would make the whole car shake.
Is this normal?
