i do normal drain of 4.2q and add 5q then drive for 15 minutes to reach 122f and open the level check bolt while engine on the drain becomes steady thin after 200ml out so the level right now inside is 10.4q while manual 7.7q for atf amount it kinda confused the shift is quick responding quite operation and no leak or overheating sign
